SirShaManIX Posted July 16, 2014 Report Share Posted July 16, 2014 Hi I'm just wondering if I connect the Flirc to my Boxee, will it be able to start the Boxee when it's shut down? Basically just like the RF-remote for Boxee is able to do today. The Boxee is powered of and at the press of a button on the RF-remote the Boxee starts. Can the Flirc do the same thing but with IR? Or do I have to start the Boxee with the button on the Boxee (or via the RF-remote) and then be able to control it with the Flirc? Thanks in advance Quote Link to comment Share on other sites More sharing options...
jason Posted July 16, 2014 Report Share Posted July 16, 2014 Unless they are doing something proprietary, they have to be in a sleep state, if they are, then yes, it's possible. Quote Link to comment Share on other sites More sharing options...
SirShaManIX Posted July 16, 2014 Author Report Share Posted July 16, 2014 (edited) I don't think the Boxee even has a sleep mode :/ But I'm not sure. Have to look it up. Thank you. Edited July 16, 2014 by SirShaManIX Quote Link to comment Share on other sites More sharing options...
