henningdalgaard 0 Report post Posted January 22, 2015 ok, great! I guess it will be announced in this thread? Quote Share this post Link to post Share on other sites
jason 156 Report post Posted January 22, 2015 yeah, and twitter, and the web, etc. But here first. Quote Share this post Link to post Share on other sites
reni10 0 Report post Posted January 23, 2015 Yes, I keep asking people to be a little patient. A flirc, firetv will be added to harmony in the next day or so. But even if you didn't have a harmony, it will work with any remote. When you say it will be added to Harmony do you mean in the Harmony setup software or in the Flirc Setup software? Quote Share this post Link to post Share on other sites
jason 156 Report post Posted January 23, 2015 When you say it will be added to Harmony do you mean in the Harmony setup software or in the Flirc Setup software? a Flirc FireTV profile will be added to the harmony database and a firmware image will be released that has these keys pre-pared. 1 Quote Share this post Link to post Share on other sites
sweller 0 Report post Posted January 23, 2015 ... that has these keys pre-pared. Pun intended? :D Quote Share this post Link to post Share on other sites
reni10 0 Report post Posted January 23, 2015 a Flirc FireTV profile will be added to the harmony database and a firmware image will be released that has these keys pre-pared. I see this Flirc FireTV profile has already been added in the Harmony Software as I just had a look and was able to set up a new device using it. So this should stop the Harmony remote sending commands twice or do we need to wait for the Flirc Firmware update as well? Quote Share this post Link to post Share on other sites
jason 156 Report post Posted January 23, 2015 I see this Flirc FireTV profile has already been added in the Harmony Software as I just had a look and was able to set up a new device using it. So this should stop the Harmony remote sending commands twice or do we need to wait for the Flirc Firmware update as well? I have not announced it yet, because they have problems with the profile. For example, the enter key is not mapped by default to the 'ok' or select button on the remote Also, they don't have 'back' mapped to the 'back' harmony button either. It's going to cause a lot of confusion, you need to map these manually. Can you actually tell me if that was the case? Which remote do you have? Otherwise, yes, it will solve these problems. I have my own vendor protocol tuned for flirc. Quote Share this post Link to post Share on other sites
ImCoKeMaN 3 Report post Posted January 23, 2015 (edited) So out of curiosity, do these codes overlap? Like would xbmc (Kodi) up = firetv up? I can see benefits to storage space on the flirc to combine them, but also benefits to having 100% unique codes if there were multiple flircs in the same house and only having the one you want to respond. they are pretty sensitive =) Edited January 23, 2015 by ImCoKeMaN Quote Share this post Link to post Share on other sites
reni10 0 Report post Posted January 23, 2015 The new Flirc FireTV Harmony Profile does still NOT solve the issue of the Harmony sending multiple commands! The back button is fine now but the Direction up, down etc. are all sending multiple commands on occasion now! Still more work to be done on this I think... Quote Share this post Link to post Share on other sites
jason 156 Report post Posted January 23, 2015 The new Flirc FireTV Harmony Profile does still NOT solve the issue of the Harmony sending multiple commands! The back button is fine now but the Direction up, down etc. are all sending multiple commands on occasion now! Still more work to be done on this I think... Please save your configuration, and post it here. Quote Share this post Link to post Share on other sites
jason 156 Report post Posted January 24, 2015 Nevermind, I reproduced it. I'll try to tell logitech, but it's a harmony setting. Follow this: https://flirc.zendesk.com/hc/en-us/articles/203390449 Leave interkey delay at 5. Quote Share this post Link to post Share on other sites
jason 156 Report post Posted January 24, 2015 The new Flirc FireTV Harmony Profile does still NOT solve the issue of the Harmony sending multiple commands! The back button is fine now but the Direction up, down etc. are all sending multiple commands on occasion now! Still more work to be done on this I think... Nevermind, I reproduced it. I'll try to tell logitech, but it's a harmony setting. Follow this: https://flirc.zendesk.com/hc/en-us/articles/203390449 Leave interkey delay at 5. Quote Share this post Link to post Share on other sites
reni10 0 Report post Posted January 24, 2015 Nevermind, I reproduced it. I'll try to tell logitech, but it's a harmony setting. Follow this: https://flirc.zendesk.com/hc/en-us/articles/203390449 Leave interkey delay at 5. I tried the setting in the link on the Harmony and set the Flirc InterKey to 5 but it still sends a double command on occasion for the direction keys! Quote Share this post Link to post Share on other sites
reni10 0 Report post Posted January 27, 2015 Any update on this from Logitech? Quote Share this post Link to post Share on other sites
jason 156 Report post Posted January 27, 2015 Not yet. Can you tell me which logitech remote you have? Quote Share this post Link to post Share on other sites
reni10 0 Report post Posted January 27, 2015 Harmony 520: http://support.logitech.com/en_us/product/harmony-520-advanced-universal-remote Quote Share this post Link to post Share on other sites
reni10 0 Report post Posted January 30, 2015 Anything further on this at all? Quote Share this post Link to post Share on other sites
jason 156 Report post Posted January 30, 2015 Yeah, I can not reproduce this with the harmony, or the harmony profile. However, I can reproduce this with other remotes. I will be following up with the firetv team, the problem seems to be on there end. Quote Share this post Link to post Share on other sites
RVD26 1 Report post Posted February 5, 2015 I'm having the issue where pressing the back button generates a double-press. All the other buttons seem to work fine on my Harmony 700. Any fix for this? 1 Quote Share this post Link to post Share on other sites
Herman Trivilino 0 Report post Posted February 6, 2015 I'm having the issue where pressing the back button generates a double-press. All the other buttons seem to work fine on my Harmony 700. Any fix for this? Similar issue here with three different Sony VL Series remotes. Except I get more than a double-press. This has got to be something associated with the way the Fire TV is handling the bit stream generated by the Flirc IR receiver. Quote Share this post Link to post Share on other sites
jason 156 Report post Posted February 6, 2015 Similar issue here with three different Sony VL Series remotes. Except I get more than a double-press. This has got to be something associated with the way the Fire TV is handling the bit stream generated by the Flirc IR receiver. It is. For the harmony guys, I will put together some formal documentation shortly. But yes, it's firetv. Every operating system has a 'key repeat' and firetv is set way to short. While it appears as 'double presses' it is actually the start of a stream of characters. Think regular computer, you press a keyboard key and hold, and after a set time, the stream starts. The stream is starting on the firetv, and you only get the first key of the stream, and the original key, making you think it's two presses. I sent them a note, I don't think I can fix this in my device. One thing you can try is enabling the noise filter, which waits for multiple button hits before sending the command. For the harmony, delete, re-add firetv, and try again. They updated their settings recently. Quote Share this post Link to post Share on other sites
RVD26 1 Report post Posted February 6, 2015 It is. For the harmony guys, I will put together some formal documentation shortly. But yes, it's firetv. Every operating system has a 'key repeat' and firetv is set way to short. While it appears as 'double presses' it is actually the start of a stream of characters. Think regular computer, you press a keyboard key and hold, and after a set time, the stream starts. The stream is starting on the firetv, and you only get the first key of the stream, and the original key, making you think it's two presses. I sent them a note, I don't think I can fix this in my device. One thing you can try is enabling the noise filter, which waits for multiple button hits before sending the command. For the harmony, delete, re-add firetv, and try again. They updated their settings recently. I was able to set up my other Amazon Fire TV with the Harmony Touch just fine. All the keys work perfectly on that setup. I added the Flirc device in the Harmony software. For some reason I can't get my Harmony 700 and the Fire TV to work together properly using the same setup. Now, I get double-press on the directional buttons. When I add a random Samsung DVD player everything works except for the double-press on the back button. Quote Share this post Link to post Share on other sites
Herman Trivilino 0 Report post Posted February 8, 2015 Every operating system has a 'key repeat' and firetv is set way to short. While it appears as 'double presses' it is actually the start of a stream of characters. Think regular computer, you press a keyboard key and hold, and after a set time, the stream starts. The stream is starting on the firetv, and you only get the first key of the stream, and the original key, making you think it's two presses. It's multiple "presses". Using the FireTV stick to send RF commands directly to the FireTV, clicks are sometimes heard. It occurs with the press of any button, but usually it's only after the button has been pressed once. Thereafter each press in succession generates a single click. When I press the return key on my IR remote to send the Return command to the Flirc I usually hear multiple clicks in very rapid succession from just one press of the key, but not on the first press. Sometimes there's a slight pause between two of those clicks. Once the FireTV has been sent all the way back to the home menu, each successive press of the Return key generates a different number of clicks in rapid succession, usually too fast to count, but it seems like maybe four or five is the maximum. For the harmony, delete, re-add firetv, and try again. They updated their settings recently. I just ordered a Harmony 650. Is this a fix that applies to this remote, or is it a fix that applies to the Harmony Home and Hub that communicate via RF with the FireTV. Quote Share this post Link to post Share on other sites
fgarcor 0 Report post Posted February 8, 2015 (edited) I just wanted to share some experience with Flirc since I attached to my fireTV. 1. I had a lot of problems after flashing the device to the v3.5. For example, the not detected key every two presses. Or taking long to detect them and then suddenly execute all the buttons extremely quickly. However, I got rid of them with the following settings: C:\Program Files (x86)\Flirc>flirc_util.exe settings flirc_util version v1.3.4 [v1.3.4+] Firmware: v3.5 [77E94DBB] Settings: sleep detection: Disabled noise canceler: Disabled inter-key delay: 3 seq. modifiers: Disabled state: 0 builtin profiles: Disable 2. I was playing with my riitek i13 that is an IR remote control with RF keyboard, and I realized that the following keys are mapped as follows: - Home button -> ZoomOut for the browser, multimedia key - Microphone -> ZoomIn for the browser I do not know if that is specific of my configuration, because I have a Xposed Module and a rooted fireTV, but my feeling is that it is common configuration. If somebody could confirm it that would be great. Now I am just missing the continuous key press, as if I keep the key pressed it should repeat the key and I don't have to press it multiple times. I am sure that by changing the settings I disabled that by mistake, but I couldn't find any guide about what are the settings for. Questions: ------------- a. Is there any guide that explains what do the different settings do? b. Can you confirm that the ZoomIn / ZoomOut trigger these functionalities? Thanks a lot for this piece of hardware! as now I can even set to standby my fireTV, something that I couldn't do before with the fireTV remote, and I can control my volume and assign different keys to my setup. [EDIT] Btw, it is the noise canceler the one that makes the detection of only one every two presses. Edited February 8, 2015 by fgarcor Quote Share this post Link to post Share on other sites
jason 156 Report post Posted February 8, 2015 I just wanted to share some experience with Flirc since I attached to my fireTV. 1. I had a lot of problems after flashing the device to the v3.5. For example, the not detected key every two presses. Or taking long to detect them and then suddenly execute all the buttons extremely quickly. However, I got rid of them with the following settings: C:\Program Files (x86)\Flirc>flirc_util.exe settings flirc_util version v1.3.4 [v1.3.4+] Firmware: v3.5 [77E94DBB] Settings: sleep detection: Disabled noise canceler: Disabled inter-key delay: 3 seq. modifiers: Disabled state: 0 builtin profiles: Disable 2. I was playing with my riitek i13 that is an IR remote control with RF keyboard, and I realized that the following keys are mapped as follows: - Home button -> ZoomOut for the browser, multimedia key - Microphone -> ZoomIn for the browser I do not know if that is specific of my configuration, because I have a Xposed Module and a rooted fireTV, but my feeling is that it is common configuration. If somebody could confirm it that would be great. Now I am just missing the continuous key press, as if I keep the key pressed it should repeat the key and I don't have to press it multiple times. I am sure that by changing the settings I disabled that by mistake, but I couldn't find any guide about what are the settings for. Questions: ------------- a. Is there any guide that explains what do the different settings do? b. Can you confirm that the ZoomIn / ZoomOut trigger these functionalities? Thanks a lot for this piece of hardware! as now I can even set to standby my fireTV, something that I couldn't do before with the fireTV remote, and I can control my volume and assign different keys to my setup. [EDIT] Btw, it is the noise canceler the one that makes the detection of only one every two presses. You should change your interkey_delay settings in the gui to 5 or 6, that should help the repeat I'm not sure what you mean zoomin/zoomout? You referring to Kodi? How are you doing your standby? Did you map a specific key? Quote Share this post Link to post Share on other sites
