tonyski
Using Flirc with Amazon fireTV
I've just got a Fire TV and Flirc to use with my Harmony.
I downloaded the Flirc/Fire TV device on to the remote, plugged the flirc into the Fire TV and it works great.
But - there are important commands missing. For example, there's no "info", no "stop", no pop up "context"  menu button.
Where can I get them from?
Edited by keiron99
Thanks but I am not sure what you mean.
I downloaded the Kodi app onto my FireTV.
I downloaded the Flirc Fire TV configuration onto my Harmony.
I plugged the Flirc into the Fire TV.
But I am limited to the same number of controls on Kodi as all other apps on the Fire TV.
So, there's no info button, and no context menu, for example.
Is it just a limitation of Kodi on Fire TV
Kodi is considered a separate device.
What you'll want to do is Add another device to your harmony. Manufacturer 'Flirc'. Device 'firetv'
That will add all the specific firetv buttons. Kodi has a bunch more buttons, so it's worth it to keep them both.
Let me know if that makes sense. See here for step/step instructions: https://flirc.gitbooks.io/flirc-instructions/content/universal-remote-controls/logitech-harmony-remote-controls/firetv.html
Get out of your activity, and select the FireTV device exclusively. If you see the buttons are there, then it's a matter of getting them into your activity. If they aren't there, we've got a problem with the harmony software, I really don't think that's the case. I have a 650 somewhere I can try and test this on.
Just a couple of things that I can't get to work.
I cannot get "codec info" to show
Nor can I get the page up/down to work (which really helps when scrolling through large libraries)
Any ideas, please?
Clicking OK/select while playing will bring up player options I believe it also has codec info.
For scrolling page at a time of listed library. Press right. Which move to the scroll bar. Then press down to go down a page.
Then press left to move off the scroll bar and down to move down 1 item at a time.
Hi
I am on the same boat, have got Harmony Ultimate, Fire TV Gen1 and FLIRC on firmware 4.12. I cant get the long press home button working. if I double click I get a help screen on long press. But long press just keep sending the home key repeatedly.
Have we got a solution or we are still without a solution.
Thanks
Edited by jainpankaj
On 3/3/2018 at 11:11 AM, jainpankaj said:
Hi
Thanks
See my post today that shows how to do this with a 650. Not sure if it'll work with an Ultimate, but worth a go?
