JmanHiggs Posted April 27, 2014 Report Share Posted April 27, 2014 I'm trying to use my rf harmony hub to control my raspberry pi which has the flirc plugged in. How do I do this Quote Link to comment Share on other sites More sharing options...
Budwyzer Posted April 28, 2014 Report Share Posted April 28, 2014 A link to what device you are using would be helpful. Is it This One? If so, it comes with a couple of IR blasters, that you would need to point one at your Flirc. Quote Link to comment Share on other sites More sharing options...
Bubbagump Posted April 28, 2014 Report Share Posted April 28, 2014 I too would love to get this going. I just purchased my Flirc a few days ago. I have gotten it to work with the hub... kinda. I have the Harmony Ultimate so on my remote I went into the settings and then into the area where you specify where the IR comes from and set it for that device to come from the remote instead of the hub. Then I programmed Flirc and set the remote back to IR broadcast from the hub. I could have taken my laptop to my theater room but I'm lazy. ;) I did find that in the remote settings if I had "All" as my IR broadcast then nothing came out of the remote, it was all from the hub. Now... If someone could just point me in the right direction for not needing to press every button twice for XBMC to do something I'd be all set. I've read that I need to program each button twice but when I press it says the button is recorded.. Does that imply I need to press the button on the remote again and Flirc is still recording or do I record, then re-record the button yet again. Hard one to describe in words.. A video would be nice. Quote Link to comment Share on other sites More sharing options...
Bubbagump Posted April 28, 2014 Report Share Posted April 28, 2014 May have found an answer to my own question here.. Have to give it a shot tonight.. http://blog.flirc.tv/flirc-has-a-harmony-profile/ Comments also said to make sure and use Flirc as a manufacturer and XBMC as the model in myharmony.com. Then in Flirc clear out the current config and in the advanced settings check "Builtin Profiles". Hopefully this will work. Quote Link to comment Share on other sites More sharing options...
Bubbagump Posted April 29, 2014 Report Share Posted April 29, 2014 Well... apparently this has turned into my own personal thread. Long and short, it worked perfectly. No crazy attempts of recording twice needed. Quote Link to comment Share on other sites More sharing options...
Budwyzer Posted April 30, 2014 Report Share Posted April 30, 2014 Excellente! Glad to hear that it's working. Quote Link to comment Share on other sites More sharing options...
