Upgraded firmware and can no longer record remote buttons
sifuhall
I just got my flirc and it came with firmware 2.0.
My remote is the Harmony Ultimate and while I could record my remote buttons I was having trouble as it seemed the direction arrow up and direction arrow right were sending the same command.
I upgraded my flirc firmware to 2.4 and cleared the configuration to start again and now I cannot record any remote commands at all.
Can I revert to an earlier firmware?
What error are you getting when you try to program a button?  Button Already Exists, or, Not Room For New Buttons?
http://forum.flirc.tv/index.php?/topic/1058-unable-to-reset-flirc/?hl=firmware#entry6779
I'm still looking for the firmware stuffs.
Do you have the XBMC Profile activated?  From what I've read it's paired to the Harmony One, specifically, so the codes pre-programmed in may be mish-mashed codes of what your Harmony Ultimate is sending out.
